Example Code
Run Macro in an Excel File Using TestStand ActiveX/COM Adapter
    Other
  • TestStand
Code and Documents
Description
This TestStand example sequence is created based on LabVIEW's Excel - Macro.vi shipping example.
The sequence will open an Excel file and run the embedded GraphData macro.
LabVIEW Code as below snippet.
Equivalent TestStand Sequence
Additional Information
This example is tested with TestStand 2022 Q4 32-bit and Microsoft® Excel® for Microsoft 365 MSO (Version 2309 Build 16.0.16827.20166) 64-bit
