Overview
This VI acquires an image from a camera and rotates the image to a specified angle. You can modify the rotation angle on the fly.
Description
Use your GIGe, USB or Firewire camera to aquire an image. The livestream can be rotated using the angle input below the meter.
Requirements
Vision Acquisition Software 8.0 "or compatible" (NI IMAQdx)
Vision Development Module 8.0 "or compatible"
LabVIEW 8.0 "or compatible"
1.) Make sure the software listed above is installed and activated
2.) Test out the camera using Measurement & Automation Explorer (MAX)
3.) Close MAX and open the example the attached example in LabVIEW
4.) Select the tested camera using "IMAQdx Session"
5.) Run the example
6.) Change angle input to rotate the image with a certain degree
This is coded in LabVIEW Version 8.0. This particular code requires Vision Development Module to be installed. It uses IMAQdx VIs, but you can easily replace all of the IMAQdx VIs with IMAQ VIs if you have an analog, Camera Link, or Parallel Digital camera.
Thanks for posting. Please rename your attachment to include the LabVIEW version ("_lvXX.vi") and add an image of the code to give us an idea of what we're downloading.
