Overview
This code allows the user to rotate a set of XY Coordinates about a pivot point.
Description
This VI uses the Geometry VIs to rotate a set of XY Coordinates. The user Set the Points to Rotate, the Rotation Angle and the Pivot Point using 2D Cartesian Coordinate Rotation VIs the Coordinates are rotated and the XY Graph shows: Original Array Points, the Rotated Points and the Pivot Point.
Requirements
LabVIEW 2012 (or compatible)
Full Development System is required for use of the Geometry VIs
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
