Example Code
Rising Edge Counter with Threshold Control
Code and Documents
This example demonstrates how the NI PXI-6652 and PXI-6653 inputs can be used with different families of digital logic by varying the threshold value. It takes a periodic digital signal (such as a clock or a pulse train) on the PFI0 port of an NI PXI-6652 or PXI-6653 and counts rising edges across a user-defined threshold voltage. It uses the FPGA on these devices to count these edges and, based on a timed-loop in the FPGA code, measures period and frequency. The threshold can be set to several common, predefined values, or the user can set his own custom threshold.
Contributors
