Overview
This example demonstrates how to perform a ring acquisition in LabVIEW using IMAQdx.
Description
This VI creates a ring buffer by creating an array of uniquely named buffers and passing it into the while loop where the acquisition takes place. The VI continuously cycles through the array of buffers using the quotient remainder function and index array. The Start Rewind button on the front panel allows you to display the entire array of buffers. It is mainly for demonstration purposes, but also has a practical application of a rewind function. Some applications use vision to monitor a test, and if an event occurs, the operator may want to save the current image along with a set number of frames leading up to the event. This VI can be easily modified for such an application by adding in a save function.
Requirements
Software/Hardware
LabVIEW 2013 SP1 or earlier
Vision Acquisition Software
Any camera compatible with IMAQdx
VI Snippet
