Example Code
Retrigger Analog Input with Analog Trigger Using LabVIEW
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example VI shows how to retrigger a counter task by using the analog comparison event.
Description
This VI uses the analog comparison event to retrigger a counter task.  The counter output is used as the analog input sample clock.  This allows you to have a retrigger analog input task with an analog edge trigger.
Requirements
  • LabVIEW 2012 (or compatible)
  • NI DAQmx 12.0 (or compatible)
  1. Choose the correct resource name for your device.
  2. Select the number of samples and sampling frequency.
  3. Set the counter output to use as the sample clock. Verify that the sample clock source is the PFI line corresponding to the counter used. This can be found in the device pinouts.
  4. Select the analog trigger level and slope that is desired for the trigger.
  5. Run the VI
NI Snippet
Jordan F
Comments
pflores
NI Employee (retired)
on
The title says Analog Trigger, but the screenshot looks like the counter task has a Digital Trigger.
hmmmmm...
Peter Flores
D*
Member
Member
on
The Analog Trigger is configured in the bottom task.  The Analog Trigger circuitry inputs an analog signal and outputs a digital signal based on the Analog Trigger configuration (level, hystersis, etc). That digital output signal can then be used to start any task.  In this example it is routed to trigger the counter in the top task.
