Overview
This short example demonstrates how to obtain the text which is selected by a user in a string control on a LabVIEW Front Panel.
Description
This short example demonstrates how to obtain the text which is selected by a user in a string control on a LabVIEW Front Panel. This program uses an event stucture and the Mouse Up event of the string control to update the Selection indicator after the user makes a selection. To use the example, simply run the VI and select some text in the String Control. The example should be compatible with LabVIEW 8.5 and later.
Requirements
VI Block Diagram
