Example Code
Retrieve Array Element Types in a Cluster By Reference
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
This example VI demonstrates how (by cluster reference) to determine the element type of an array within our cluster.
Description
In working with clusters by reference, some information of the objects within clusters is unavailable.  One such example is the array element type.  It is important to understand the the properties and methods a cluster has must be available and shared among ALL objects within.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI.
  2. Check the class property in the middle pane and the data type in the third pane.
VI Block Diagram
Cole R.
Software Engineer
Comments
Olivier_L
Active Participant
Active Participant
on
What about defining the Array element types if the type is a cluster?
How to get a reference of the array elements to get the inside cluster architecture?
Olivier L. | Certified LabVIEW Developer
Cole_R
Member
Member
on
Hi Olivier_L,
From the array reference, you should be able to use the property node to get the ArrElem reference.  From there, you can move to the more specific cluster class and get the objects within the cluster.
Something like this should work for you.  Hope this helps!
Cole R.
Software Engineer
