This LabVIEW example has examples of resolver simulation and measurement on both Windows and FPGA targets.
Resolvers produce a sine / cosine signal that is modulated with a carrier frequency. Decoding the sine and cosine signal is done using the arc-tangent function available in LabVIEW FPGA (which uses a cordic algorithm).
Simulation in the example produces an excitation signal (carrier frequency) and sine / cosine signals based on a input position in degrees. Fixed point math is used.
In the FPGA examples, 1 cycle of the carrier frequency sine wave is generated from the host VI and stored in a LUT (Look Up Table) in FPGA. The sine and cosine values are multiplied by the LUT values to create the appropriate modulated output signal.
Hi, is there any hardware description and software requirements that we can use with this example?
