Example Code
Resize PNG canvas
Code and Documents
Overview
Resize PNG images by changing the DPI (Dots per meter for PNG files)
Description
Opens a PNG file and changes or add's the "Dots per meter" meta data of this file.
If you know the number of dots (x and y) then you can calculate how big the canvas should be.
Example:
x = 1000 dots
y = 500 dots
Picture should become 10x5 cm
x [dpm] = x [#dots] / size ----> 1000 [#dots] / 0.1 = 10000 [dpm]
y [dpm] = y [#dots] / size ---->  500 [#dots] /0.05 = 10000 [dpm]
* [dpm] = dots per meter, used by PNG files to determen the scale
  1. Select PNG file
  2. Calculate the dpm (dots per meter) needed, from the original file sizes
  3. file is converted (no data is changed ! only the physical size)
Requirements
Software
LV2013 sp1
ZLIB CRC32__ogtk.vi (openg)
Hardware
Additional Images or Video
Contributors
