Example Code
Resistor Calculator Example using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example calculates the theoretical value of the resistor based on the supplied band colors.
Requirements
LabVIEW Base Development System 2012 or compatible
Description
 This VI takes an input of 3 different resistance band colors and calculates the resistance of the corresponding resistor. The VI utilizes case structures for each popssible color, and contains the value for the specific resistance. There is also a boolean indicator that will illuminate if an invalid color is typed in.
  1. Run the VI
  2. Select the values of bands 1-3 from drop down menu
  3. the Resistor Value changes when changing the bands colors
  4. If the user doesn't select any color, the output will be (-1) and Invalid Color LED will turn ON
Top-level VI Code Snippet
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Chris Van Horn
