Example Code
Renaming Plot Lines on a Digital Waveform Graph
Code and Documents
Overview:
This VI programmatically change the names of the plot lines by using the Set Waveform Attribute VI.
Description:
Other attributes can be viewed in the help for the VI. This VI takes an array of strings and renames each Line accordingly.
Requirements:
  • LabVIEW 2012 (or compatible)
Steps to Implement or Execute Code:
  1. Press some boolean controls in different columns.
  2. Run the VI.
  3. Add some names in New Names control.
  4. Run the VI and see the changes in the plot names.
 Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**"
Comments
D*
Member
Member
on
This doesn't work with a Mixed Signal Graph? I find the names show up in the Digitial Waveform Graph, but not on the Mixed Signal Graph.
