Example Code
Remove Duplicate Entries in Sorted 1D Array Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI removes duplicate adjacent entries in a 1D array. If entries are not adjacent, they will not be removed
Description
Some sorted 1D arrays, contains duplicate adjacent entries. Use this VI to remove them. If entries are not adjacent, they will not be removed, which makes it the best way working with sorted lists. The VI also contains Context help description, which can be displayed either hoovering on the VI icon, or using it as a subVI
Requirements
LabVIEW 2012 (or compatible)
  1. Manually Initialize the Input Array
  2. Run the VI
  3. To display Help for this VI, Select Help»Show Context Help and move the cursor over the VI icon to display help for this VI
VI Block DiagramRemove Duplicate Entries in Sorted 1D Array LV2012 NI Verified BD.jpgRemove Duplicate Entries in Sorted 1D Array LV2012 NI Verified BD.jpg
VI Context Help Window
Remove Duplicate Entries in Sorted 1D Array LV2012 NI Verified  context help.jpgRemove Duplicate Entries in Sorted 1D Array LV2012 NI Verified context help.jpg
**This document has been updated to meet the current required format for the NI Code Exchange. **
Dan King
Comments
Mike_Powers
Member
Member
on
Nice, very helpful.  I was surprised LabVIEW didn't natively have a block like this.
Eleftherios
Member
Member
on
Thank you!
Just to mention I found out there is a buffer effect, even when it does not get anything as an input it remembers the previous outcome, that you can remove by initializing the first shift register.
