Example Code
Reducing DAQ Output Precision Using LabVIEW with DAQmx
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI converts the output of the DAQ card and lets you choose the Digits of Precision.
Description
Assume the DAQ output is 5.23145 and the required precision is 5.231. Select the Digits of Precision to be three to make output of the ring control to 1000, which will get multiplied with the DAQ output and then get converted to I16 and then divided by the output of the ring control that is 1000.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download and open the attached VI.
  2. Specify the Digits of Precision in the front panel.
  3. Run the VI .
VI Snippet
