Overview
This example shows the new drag and drop recursion interface to generate the Fibonacci sequence.
Description
A recursive function calls itself as a part of its own definition. Recursion is an advanced programming concept that can be used to reduce the complexity and size of code required to implement iterative algorithms. This article will explain how VIs can be called recursively in LabVIEW 2009 or later. There are several well-known algorithms that are commonly implemented using recursion, including a binary tree, a Fibonacci sequence, or the calculation of a factorial, as shown below. A reentrant VI can be placed onto its own block diagram for use in a recursive algorithm by dragging the icon of a VI to its own block diagram.
Requirements
Software:
- LabVIEW 2012 (or compatible)
1. Enter the order of Fibonacci series.
2. Run VI.
3. Observe the Fibonacci numbers at the indicator.
**This document has been updated to meet the current required format for the NI Code Exchange.*
