Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Example Code
Reconnectable TCP Server Connection
Code and Documents
Overview
One important feature of any server is the ability quickly establish a connection from any client, complete the transaction, and reinitialize to wait for the next connection. This is an example of how to use the TCP Listen VIs to accomplish repeatable connections.
The attached vi creates a listener port on the current system and allows the user to open a TCP connect with this ip address and the specified port. This vi starts off by getting the default IP address for the system if the user doesn't enter in an IP address(w/ .) in the string field. It then creates a TCP listener. As soon as a connection is established it displays the IP addres of the connecting computer and closes the connection. The TCP Listen VI handles the closing of the listener with the next iteration.
The TCP Listen VI incorporates both the Create Listener and Wait On Listener VIs to help users create server applications to open connections and reinitialize them once a connection has been established to wait for the next connection from another client.
png of attached vi
Contributors
