Overview
This simple example shows that a basic heartbeat VI can assist greatly in troubleshooting startup executable and headless VIs.
Description
This VI must not be placed as a subVI inside of a loop. It contains an infinite loop and will therefore never return, blocking higher level loops from running. This VI must be located under a Real-Time target, or the RT Utility VIs will not be found by LabVIEW and the VI will appear broken.One of the most challenging aspects of programming in Real-Time is determining if your program is in fact running on the target.
Requirements
There are two ways to use this VI:
Approach 1 (for VIs or Executables): The RT Startup Heartbeat.vi can be placed as a subVI on the top level target VI to indicate when that VI is running on the target. It should not be placed inside of a loop; the VI contains its own infinite loop and will therefore never return.
Approach 2 (for Executables Only): The RT Startup Heartbeat.vi can be selected as a Startup VI in the Build Specifications of a Real-Time Executable.
In either setup, this VI will blink the User LED on the Real-Time target and write out CPU usage to the console.
VI Snippet
Tried using the LabVIEW v11.0 file. But it's looking for "RT Get CPU Loads.vi." Where do I get that VI?
Sounds, looks awesome but it doesn't come with the following subVIs:
RT Get CP Loads.vi
RT Debug String.vi
