Functional Description
This VI´s shows, how to read the absolute Encoder Position from the BaumerIVO-Encoder (GBAMH) with the National Instruments CANopen Library.
Caveats and Additional Notes
What you need to get started:
At least
for further Communication Possibilities here, to have a look at the Baumer Manuals for CANopen Devices:
http://www.baumerivo.com/pdf/handbuch/Manual_CANopen_EN.pdf
#1: Set the Baudrate of the CAN Device in MAX, same as set at the Encoder (DIP-Switches) (for example 125kBaud)
#2: Open the attached Project
#3: Choose SDO or PDO Example
SDO: Easy example, done for a single value.
PDO: More advanced, but possibilities for higher transfer.
#4: Set the appropriate Interface, Baudrate nad Node ID
#5: Run the Example
Description-Separate-2
Thanks for posting! Could you please add a screenshot of your code? Also, please rename your attachment to include the LabVIEW version. "_lvXX.zip" would be fine.
