Example Code
Reading the Values and Item Names From a Combo Box
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to read the values from a combo box programmatically without user input.
Description
This code was developed as an example to programmatically change the way combo box values and item names were read from.  With this example all values and item names from the combo box are available to read and use at will.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Configure the combo box with item names and values
  2. Run the program
  3. Use the index control to view the selected value and item name
  4. Observe values changing in relation to the index selection
  5. Click the 'Stop' button when complete.
VI Block Diagram
Bobby Breyer
