Online shopping is currently unavailable.
Please contact us for help or try again later.
Example Code
Reading Data from Excel
Code and Documents
This vi will give you access to Data in EXCEL sheet (row and column).
Select open Excel file, select range of row and column from which data is to be read, and then click open.
You will get respetive row and column data.
Press open only once.
The array and string on the right are simply to get the correct data types, and don't need any inputs.
Chris Van Horn
Comments
mwatkins
Member
Member
on
excellent work Chris_VH. I just successfully tested in LV2019 reading a Office 360 ProPlus Version 1908 (Build 11929.20606) excel file.
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
Brzhou123
Member
Member
on
Hi Sir,
Could you add a portion for write data to txt ?
Thanks.
Keep moving
Contributors
