Example Code
Reading Data From Excel Using The Report Generation Toolkit
Products and Environment
    Software
  • LabVIEW Report Generation Toolkit
  • LabVIEW
Code and Documents
Description
Overview
The example demonstrates how to use the LabVIEW Report Generator Toolkit to read information from an Excel file.
Description
The Report Generation Toolkit uses the ActiveX interface to Microsoft Excel to interface with Excel spreadsheets. Using the pre-implemented functions from the Report Generation Toolkit also makes it possible to read data from an Excel spreadsheet.
Requirements
 Software
  • LabVIEW 2012 Base Development System (or compatible)
  • LabVIEW 2012 Report Generation Toolkit (or compatible)
  • Microsoft Excel (see Knowledgebase KB 3EJEC9NS)
 Hardware
  • No hardware is necessary to use this example VI
  1. Open the attached file
  2. Run the VI
Read Data From Excel - Front Panel.pngRead Data From Excel - Front Panel.png
Read Data From Excel - Block Diagram.pngRead Data From Excel - Block Diagram.png
Knowledgebase: KB 3EJEC9NS: Report Generation Toolkit Compatibility with Microsoft Office and LabVIEW
https://www.ni.com/en/support/documentation/compatibility/17/report-generation-toolkit-and-microsoft...
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
Comments
K.Nishihara
Member
Member
on
