Description
Description-Separate-1Small sub vi to make the XML string more readable for myself.
This is used to redo the output of the "Flatten to XML" to get a more readable string format.
This string format is compatible with the "Unflatten From XML" function.
Description-Separate-2How to Use
How-Separate-1XML string in from "Flatten to XML"
XML string out to string indicator.
How-Separate-2Additional Information
Additional-Separate-1Extra input for the tokens used (can be altered by user if needed)
Additional-Separate-2
