Example Code
Read from Spreadsheet In Chunks in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to read a specified amount of lines from a Spreadsheet File at a time.
LabVIEW doesn't have to read in the entire document each time, but rather "x" Number of Lines at a time.
Description
Read from <text File VI with Read Line property set outputs the values of the specified .txt in the Number of Lines. For loop with the Concatenate function converts a 1D Array of lines into one long string and Finally the Spreadsheet String To Array function converts one "spreadsheet" string into a 2D Array of strings. It is parsed by default as tab delimited and line return between rows.
Requirements
LabVIEW 2012 (or compatible)
  1. Type the Number of Lines in that control
  2. Run VI
  3. Provide a .txt file location when prompted
  4. Spreadsheet information Array Indicator shows the values of the specified .txt in the Number of Lines
  5. Final 2D Array loads the values from Spreadsheet information Array Indicator in case there is a spaces between values in the same line
Jonah Paul
Marketing Manager, NI Software
Comments
HunterSeeker
Member Member
Member
on
Could you please add a screenshot of your block diagram and/or front panel.
Todd S.
NI Employee (retired)
on
Thanks for posting!
Todd S.
LabVIEW Community Manager
