Example Code
Read data from .dbc database and put it in a tree indicator
Code and Documents
Overview
The VI shows how to read the .dbc database data into a tree indicator.
This is done usinf the XNET API from NI
Description
This VI is just a demonstation of using the XNET API to fetch data from a .dbc file.
An analysis is performed and the data is written into a tree indicator.
The VI shows the the performance difference between the usage of 'defer panel updates' and not too.
Further more the LabVIEW cursor API is used to show the cursor busy function while tree operations.
  1. Select the .dbc database file using the I/O variable
  2. Press the run button
Requirements
Software
LabVIEW 2014
XNET API
Hardware
none
Additional Images or Video
Comments
Aaron_hangzhen
Member
Member
on
Hello Kunze,
I read your works"Read data from .dbc database and put it in a tree indicator".
It can read data from dbc,and show dbc's numbers in tree indicator.
But I have some iusse about your works.
Why tree indicator is string type?
Could I link a out Control after tree?
I failure  I link a string and a string array.but failure.
Thanks.
Contributors
