Overview
This VI reads different types of data from an .ini file
Description
The INI file format is an informal standard for configurations files for some platforms or software. INI files are simple text files with a basic structure composed of sections, properties and values. The name "INI file" comes from the commonly used filename extension .INI, which stands for "initialization".
This VI opens an INI file, which its path is provided by the user using the Configuration File Path control, and reads multiple types of data types from the file- Boolean, Integer and string
Requirements
LabVIEW Full Development System 2012 or compatible
1.Browse to the test.ini file location on your disk, and provide it to the Configuration File Path control
2. Run the VI
Notice that the indicators now reflect the information from within test.ini file
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Very usefull. Thanks
But how can you initialize a Multicolumn ListBox, for example?? Line-by-line?
