Example Code
Read Password Protected Excel File Using ActiveX
Products and Environment
    Software
  • LabVIEW
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Description
This example will open a password-protected Excel file and read the data from the specified sheet and range.
The data will be shown in LabVIEW as 2D string.
You can change the data format and range as required by modifying the code.
How to Use
Refer to Microsoft Excel namespace documentation in the Related Links section for the details of each class, method, and properties.
Additional Information
This example was tested with LabVIEW 2023 Q1 64-bit with Microsoft® Excel® for Microsoft 365 MSO (Version 2309 Build 16.0.16827.20166) 64-bit.
It is recommended to use the same LabVIEW and Microsoft Excel bitness.
Related Links
