Overview
This simple VI can be used to read values from an instrument, connected using a Sylvac Simplex OPTO RS232.
Description
The attached zip file includes three examples. Two examples allow you to continuously read from your Sylvac device, the third example allows you to read a single measurement from your device.
To run these examples you must first install the Sylvac driver.
Requirements
Software
LabVIEW 2012 (or compatible)
Sylvac Driver
Hardware
Instructions
1.Open the code
2. Select the port where instrument is connected
3. Run VI
**This Example has been updated to meet the current required format for the NI Code Exchange**
Hi
Can I use this code to connect Syring Pump using RS-232 to PC?
I appreciate if you help me out.
Or should I have Syring driver?
Mo
