Example Code
Read Front Panel Location from an Initialization file Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This vi will read size and location values of a front panel from an initialization file then move the front panel to that location and size.
Description
This vi will read size and location values of a front panel from an initialization file then move the front panel to that location and size. Meant to be accompanied with
https://decibel.ni.com/content/docs/DOC-36155
Requirements
  • LabVIEW 2013 (or compatible)
  1. Put the FrontPanelResize.ini file in the same directory with this VI, make sure it has correct content.
  2. Fill in the path of the VI to resize in the file path constant on the block diagram.
  3. Run the VI.
VI Snippet of Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Applications/Systems/Test
National Instruments | AWR Group
