Example Code
Randomize an Array Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will randomize the order of Input Array elements
Description
This VI is effectively the reverse of the Sort 1D Array VI. it will take the Input Array and randomize the order of its elements. First, the VI initializes an empty array and gets the size of the array input. At every iteration, it will generate a random number and multiply by the array's size, representing an index in the array. If this value is not in the array, insert it. The loop is stopped when the placeholder array has the same number of elements as the input array. Finally, the input array is indexed with the Randomized Array. This is only one possible method to randomize an array's elements.
Requirements
  • LabVIEW 2012 (or compatible)
1. Manually Initialize the Input Array
2. Run the VI
VI Block Diagram
Randomize Array LV2012 NI Verified BD.jpgRandomize Array LV2012 NI Verified BD.jpg
Product Support Engineer
Comments
JLSx
Member
Member
on
That's very nice!  Haven't played yet as the VI is still queing (virus scanning) but I can already see several nice use cases for this when testing and wanting to create data sets etc.
Thanks for posting!
Best,
JLSx
Sixclear
VI High - LabVIEW Programming Video Blog
altenbach
Knight of NI Knight of NI
Knight of NI
on
For a better solution, see my comments at the bottom of the page here.
