Example Code
Random Sound Generator
Code and Documents
Overview
This example allows the user to set up to three frequencies or randomly choose three frequencies. The sound file is then saved as .wav file.
Description
This code establishes a sound task that takes up to three frequencies and plays them simultaneously. The user is able to dynamically change the frequencies and volume and the sound output is saved in a file titled RandomSoundGenerator.wav .
Requirements
  • LabVIEW 2012 (or compatible)
  • Windows Media Player
  1. Download and Open VI
  2. Set up to three frequencies
  3. Run the VI
  4. Manually set the frequencies with the "User Input" button or randomly set the three frequencies with the "Randomize" button.
  5. Press the "Stop" button to save the generated sound
Front panel
Block Diagram
Jonathan L.
Technical Support Section Manager
