Overview
This example demonstrates how to use multiple NI-RFmx personalities (e.g. LTE and WCDMA) within a single VI and use the same RFmx handle.
Description
This example demonstrates how to perform EVM measurements with RFmx on WCDMA and LTE signals located at different carrier frequencies.
The example code is structured as follows:
1) An LTE waveform is generated using NI-RGSG Playback Library API and LTE EVM measurement is performed.
2) Once the LTE EVM mesurement is complete, a WCDMA waveform is generated and WCDMA EVM measurement is performed.
3) Results (Constellation plots, EVM traces, etc.) are displayed on the front panel.
Instructions
1. Configure RF hardware settings (HW Resource Name, carrier frequency, generation power level, etc.)
2. Run this VI.
3. Use tabs to select between LTE and WCDMA EVM measurements.
Note : Support file for the Reference Waveform File path should be present in the Support directory located in the same folder as this example.
( Support Files are attached with the example code below )
Requirements
Software
LabVIEW 2013 or higher
NI-RFmx WCDMA 2.0
NI-RFmx LTE 2.0
NI-RFSA 14.1
NI-RFSG Playback Library 2.0
Hardware
5644R/5645R/5646R/5668R
Additional Images
not working at me Error -200220 occurred at niRFSG Initialize.vi Device identifier is invalid.
You would need to change the default hardware "Resource Names" for generation and analysis (i.e. VST1) to whatever hardware resource names you have on your system. To figure those out launch MAX (Start»Programs»National Instruments»Measurement & Automation) and go to "Devices and Interfaces"
Thank you very much for reply. I haven't hardware ones. Maybe you have a virtual model transmitter + radio channel (+noise) + receiver of wcdma (hsdpa/hsupa). I need constellation, EVM trace and Measurements of virtual link. Or how to add virtual transmitter for this model? Please help )
You cannot run this example with virtual hardware. If you have a recorded WCDMA waveform (raw IQ samples) you can use RFmx WCDMA API to demodulate it in the Analysis only mode. Refer to: http://zone.ni.com/reference/en-XX/help/375473B-01/rfmxspecan/rfmx_hardware_agnostic_mode/ If you require additional help, please contact support@ni.com Thanks!
When I try to run this, I get the following error:
niRFSGPlayback Read Waveform From File (1 Wfm,TDMS, CDB) Wrapper.vi<Err>
-303804 : An interaction with TDMS has caused the following error.
Error in API: TDMS
Error Code provided by the API: -6604
Error String provided by API: The file could not be opened.
I am using LabVIEW 2025, so maybe that's an issue?
Any suggestions on how to fix this?
