Per scaricare il software NI, compresi i prodotti illustrati di seguito, visitare il sito ni.com/downloads.
Overview
Coding that will allow us to measure the noise floor of our device.
Description
Noise floor is the measure of the noise density, in dBm/Hz, or the noise power in a 1 Hz bandwidth. In this specific example, we are simulating a device, and due to the nature of simulation, we will be having peak in the central frequency. However, we can simply change the "Simulate=1" to "Simulate=0" on the "Initialize with Options" VI, and this should allow us to try the code on our real hardware.
Important Notes
1. To prevent damage to your device, ensure that there are no high power RF signals beyond specified on the front panel of the device.
2. If not using Input Isolation, be sure to use a 50-ohm termination on the input for best performance and safety.
3. For best results, ensure that the device has been recently calibrated.
Requirements
1. LabVIEW 2012 (or compatible)
2. NI RFSA Driver
3. Spectral Measurement Toolkit
1. Select the device to simulate.
2. Configure the central frequency and other parameters.
3. Run the VI.
Il codice di esempio scaricato dall'Example Code Exchange nella NI Community è concesso in licenza con la licenza MIT.
