Example Code
RF Test Reference Architecture
Introduction
This is a central location to locate all code that is related to this architecture.
Introduction to the niRF Communications Reference Architecture
Refer to this document to understand how this architecture works.
Advanced System Calibration
This section focuses on calibrating or characterizing your RF test setup to achieve better accuraccy and less variation on your measurements.
All RF setups must be calibrated in order to achieve correct measurements.
This document describes an advance procedure to calibrate the RF system using a power meter as reference.
The included code requires the RF Test Reference Architecture (niBasic).
Links and Downloads
Download: niBasic Installer
Download: niFM Installer
Attached: Two Port VSWR Uncertainty Calculator
Link: NI USB-5680 Uncertainty Calculator
Gerardo O.
RF SW Engineering R&D
Contributors
