以下に示された製品を含め、NIのソフトウェアをダウンロードするには、ni.com/downloadsをご覧ください。
Overview: This basic example demonstrates how to access the Queue in different loops and subVIs by using the queue name.
Description
Queues are very helpful, particularly in Producer/Consumer architecture. We typically pass the Queue Reference between loops and subVIs in order to access its elements, but you can also just use the queue name. This example shows a queue being accessed in a subVI that is only passed the name of the queue. This could also apply across multiple loops.
Requirements: LabVIEW 2012 (or compatible). Hardware: none.
Steps to Implement or Execute Code:
1. Press Enqueued Element.
2. Run the VI.
3. See element's queued.
Additional Information or References:
NIコミュニティのサンプルコード交換のサンプルコードは、MIT Licenseによりライセンス供与されています。
