Example Code
Query XML Document for Different Expressions Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will query an XML document for three different expressions and return the output of those expressions.
Description
This VI is used to read the "/method/lowleveldata/transitiontable/transitions/string"  node from an XML file as generated by the method editor. This VI will display only the first result of each expression.
Requirements
  • LabVIEW 2012 (or compatible)
  • Specify path of XML Document (Sample XML Document is attached)
  • Specify XPath Expression
  • Specify XPath Expression 2
  • Specify XPath Expression 3
  • Run the program
VI Snippet
