Example Code
Query NI License Information Programmatically in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows the user to easily pull the serial numbers of LabVIEW, LabWindows and TestStand.
Description
This example code employs the use of Windows Access Registry API VIs to pull the serial numbers.  To access other software serial numbers, the user must find the exact software subkey within the registry.
Requirements
LabVIEW 2012 (or compatible)
  1. Select type of the software
  2. Run the VI
