Example Code
Quantizing Digital Filters Using the Digital Filter Design Toolkit in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example creates a Butterworth filter and quantizes the resulting coefficients three different ways: using a fourth order quantization structure, using cascaded second-order quantization structure, or using math VIs.
Description
Select your filter type and the type of quantization structure that you would like to use. Also, specify the number of bits that you would like to quantize your filter coefficients too. Double data types are floating point, 64-bit numbers. Many DSPs use 16-bit fixed-point numbers, so that is the default value of this VI. If the number of bits is set to 0, the VI will throw an error
Requirements
1. LabVIEW 2012 or compatible
2. Compatible Digital Filter Design Toolkit
1. Select the desired Quantization Method.
2. Select the desired filter type.
3. Run the VI.
4. Change the different configuration and run again.
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
