1. Overview
This examples shows how to use the property Val (Sgnl) [Value (Signaling)] to update a control's vale and generate a value change event.
2. Description
Firing events programmatically allows you to fire events from anywhere in the VI hierarchy. The Value (Signaling) property updates the value of an object similar to the Value property. However, the Value (Signaling) property also causes LabVIEW to generate an event as if the user had interactively changed the value of the object.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Description-Separate-2Regards,
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
