Example Code
Pull array subset based on threshold
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to pull values that are within a threshold, and the values that come after the first one that meets the mentioned threshold.
Description
This code consists on analyzing the values of an array to verify if each value is less or equal to a threshold value. Also, we will be able to take a subset of the values that come after the first number that meets the condition. Both analyses are commonly required.
Requirements
LabVIEW 2012 (or compatible)
1. Set values for the input array
2. Configure the desired threshold
3. Run the VI
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
