Introduction
The AD7991/AD7995/AD7999 are 12-/10-/8-bit, low power, successive approximation ADCs with an I2C®-compatible interface. Each part
operates from a single 2.7 V to 5.5 V power supply and features a 1 μs conversion time. Each AD7991/AD7995/AD7999 provides a 2-wire serial interface compatible with I2C interfaces.
These devices have four single-ended analog input channels, or three single-ended analog input channels and one reference input channel (see image below).
Example
The LabVIEW 2009 VI attached to this document uses the NI-8451 to write and read from the configuration registers on the AD7995, that is the VI will read the register corresponding to a channel on the AD7995. The VI will also work for the AD7991 and AD7999.
Simply input the address for the device and the configuration register to read from into the inputs.
Additional Notes
The I2C bus is a two-wire half-duplex serial interface. The two lines, Serial Data (SDA) and Serial Clock (SCL), are both bidirectional.
Each device connected to the I2C bus has a unique 7-bit I2C address to facilitate identification and communication by the master. Commonly,
the upper four bits are fixed and assigned to specific categories of devices (for example, 1010 is assigned to serial EEPROMs). The three
lower bits are programmable through hardware address pins, allowing up to eight devices of the same type to be connected to a single I2C bus.
Each device on the bus (both master and slave) can be a receiver and/or transmitter.
The Analog to Digital chips discussed in this article are Analog Devices chips.
