Example Code
Programmatically search for a device using Product Type
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example can programmatically search all of the National Instruments DAQ cards attached to machine for a specific product.
Description
This example uses a DAQmx System property node to access the list of discovered device names, and then a DAQmx Deviceproperty node to determine the product type of each of the discovered devices. If need to use a specific device type (eg. PCI-6221 regardless of the name which MAX has assigned to it
Requirements
  • LabVIEW 2012 (or compatible)
  1. Insert a specific device type.
  2. 2.Run the program, this VI programmatically search a device which connect to computer.
VI Block Diagram
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
