Overview
This example vi is used to obtain the public IP address of the mechine.
Description
This example code shows how you can use the included HTTP Client VI in LabVIEW to obtain the Public IP address of the machine it is running on. It accomplishes this by simply doing a Google search for the term "What is my IP". If you search for the same term in a browser Google will return your public IP address at the top of the search results. Then the vi simply parses the html that is returned and extracts that IP address so that it can be used in your code.
Requirements
VI Snippet
I recently tried running this VI from Japan, and it returned nothing because of Google trying to redirect me to google.co.jp... I instead tried contacting http://whatismyipaddress.com/ and parsing the http document returned by this page, which worked like a charm!
I've attached LV snippets for LV2014, in case anybody is interested.
