Example Code
Programmatically Confirm MD5 Checksum and Extract ZIP Archive Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This VI confirms that the MD5 checksums of the files are the same and then extract the files to the specified directory
Description
This example program is designed to be used in conjunction with this LabVIEW example. It assumes that there is a ZIP file as well as an MD5 checksum stored in a text file titled <ZIP File name>_MD5.txt. If both these files are present, this code will confirm that the MD5 checksums of the files are the same and then extract the files to the specified directory
Requirements
LabVIEW 2012 or compatible
  1. Provide the Zip File Path
  2. Provide the Target Unzip Directory File Path
  3. Make sure that MD5 checksum file is stored in a text file titled <ZIP File name>_MD5.txt
  4. Check MD5 Check Button
  5. Run the VI
VI Block Diagram
For more information on the MD5 algorithm, please see this Wikipedia article.
**This document has been updated to meet the current required format for the NI Code Exchange. **
