Example Code
Programmatically merge all TDMS files contained in a folder using LabVIEW
Code and Documents
Overview
This example VI demonstrates the method of iterating TDMS files, building a new "Merged" TDMS log file.
Description
This is an example VI that allows the user to define a folder containing multiple TDMS files, the VI subsequently iterates through each TDMS file in turn, building a new "Merged" TDMS log file.
It utilises the Producer/Consumer and State Machine architectures with Binary File I/O.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open the project " Merge TDMS Files 2012 NIVerified. lvproj ".
  2. Open the VI " TDMS Folder To Merge.vi".
  3. Select a path.
  4. Run the VI.
VI Block Diagram of "TDMS Folder To Merge.vi"
Jamie S.
Comments
davideboido
Member
Member
on
Please, could you provide this useful vi in a preceding LV version? At least 2010.
Many thanks
moxi
Member
Member
on
Thank you for such a great tool.
kabooom
Member
Member
on
Hi tanks for the tool.
But i have some remarks : there is a problem with the order of the file, when you build the array, you add the file at the begining, in my case the merged file was in the wrong order (first file added at the end).
It would be nice to check the date of the file and add the oldest first...
luisanro1
Member
Member
on
Thank you, the tool is very useful.
As kabooom says... how can we change the order of the merged file? (from oldest to newest)
Nicholas_Herrick
Member
Member
on
Works great! Nice job. Thank you.
flaviaf76
Member
Member
on
The tool is useful, but as and luisanro1 mentioned the order of the merged file is from oldest to newest.
To solve this problem, I add the "Reverse 1A Array" block connected to the output "Filenames" of the "List Folder" block and before the "For-loop" in the case "TDMS Check" in the "Consumer Loop" (see figure).
