Overview:
This program allows you to determine the serial numbers for you FlexRIO cards and adapter modules from your Windows or RT application.
Description
The FlexRIO platform combines the power of FPGA programming in LabVIEW with adapter modules for a variety of test applications. Often times it is useful to keep information about the actual hardware involved in performing a test. Therefore, the ability to programmatically access the hardware serial numbers for both parts of a FlexRIO can be helpful when developing a test system.
As of LabVIEW 2011 SP1 and NI FlexRIO Adapter Module Support 2.2.1 there are no VIs included on the Functions palette to achieve this functionality. However, VIs are included in vi.lib that will work. To find them, navigate to:
<LabVIEW>\vi.lib\FlexRIO
where <LabVIEW> reflects the root location for your LabVIEW installation.
The particular VIs of interest are FlexRIO_Host_QueryAttribute_U32.vi and FlexRIO_Host_EEPROMRead32.vi. To get the serial number for the PXI FPGA card portion of the FlexRIO use FlexRIO_Host_QueryAttribute_U32.vi and to retrieve the serial number of the FAM use FlexRIO_Host_EEPROMRead32.vi with an address of 4. These VIs can only be used in a host VI and cannot be used at the FPGA level.
Steps to Execute Code
Requirements
Software
LabVIEW 2011 SP1, FPGA Module
Hardware
FlexRIO R series card, Flex RIO Adapter Module
VI Snippet:
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
