Example Code
Programmatically create and open MAX Report for windows and real-time targets
Products and Environment
    Software
  • LabVIEW Real-Time Module
  • LabVIEW
Code and Documents
Overview
This example demonstrates how to programmatically create a MAX report and open it in a browser.
Description
This VI allows a user to create an xml or html report of the hardware and software for any RT system on their network or any windows target.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI System Configuration 5.3.3 (or compatible)
 Hardware
  • Real-Time target if you want to create a report for it (e.g. cRIO 9024 or compatible)
  1. Download and open the attached file "Create and open MAX Report LV2012 NIVerified.vi"
  2. Open VI and follow the instructions in Front Panel and Block Diagram and run the program.
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
robdevyogi
Member
Member
on
Doesn't look like the software versions of installed software is populated by the "MAX Generate Report.vi" connecting to a cRIO-9012 (LV 8.5.1 at least)
Rob
