Example Code
Programmatically Stop an Executable
Code and Documents
Overview
This example programmatically stops an executable using LabWindows/CVI.
Description
When run, this program will stop Notepad.exe in a similar way to Task Manager. The program iterates through each process until it finds one named "notepad.exe". It then terminates that process. If you want to change the process that is terminated, change the .exe named in line 33.
  1. Download and extract files from *.zip file
  2. Open *.prj file
  3. Open Notepad
  4. Run program, Notepad will close
Requirements
Software
LabWindows/CVI
Psapi.lib and Psapi.h (commonly found in C:\Program Files\Microsoft SDKs\Windows)
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
A_Ryan
AES
Comments
pe2
Member
Member
on
Where to get the psapi.lib and the psapi.h files?
Contributors
