Overview
This code programmatically shows or hides the scroll bars on the front panel of a VI.
Description
The user selects values on the Front Panel that determine whether or not the scroll bars are visible. The visibility and the user's actions are controlled by using the Front Panel's Property Nodes.
Requirements
Software:
- LabVIEW 2012 (or compatible)
1. Run the VI.
2. Select your desired setting on the Front Panel to show/hide each scroll bar.
