Programmatically Setting AC and DC Coupling for Individual Channels on one DAQmx Task
Código y Documentos
Adjunto
Introduction
Some DSA modules allows individual channels to be configured as either AC or DC coupled.  The DAQmx Channels Property Node can also set a combination of AC and DC Coupling must be set for different channels in that task.
Steps to Complete
Type in the channels to be AC coupled and DC coupled into their respective input controls under Coupling Parameters.  Use colons to enter multiple channels in a row (0:3 for channels 0 through 3) and commas to choose different channels (0,3 for channels 0 and 3).
Additional Notes
To choose one or the other, open the block diagram and delete the last two options for the DAQmx Channel property node.
El código de ejemplo del Intercambio de Código en la Comunidad de NI está autorizado con la licencia MIT. 
Colaboradores
