Example Code
Programmatically Seting the Range of an Indicator Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example programmatically changes the maximum and minimum values of a meter indicator to those of an array. It's possible to swap out the meter, its corresponding refnum, and property node with several other indicators and achieve the same result.
Description
The meter's range will be from the smallest value in the array to the largest value in the array
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the VI.
  2. Open the VI.
  3. Input numbers into the array
  4. Run the VI
  5. The meter's range will change accordingly
VI Block Diagram
